kodiak 450 problems HELP
Old 05-16-2011, 06:25 PM
0311whitey's Avatar
Default kodiak 450 problems HELP
im new to the forum just got a project 2004 kodiak 450 it has a k&n air filter, stock exhast but the baffle was removed and power tip was added, it also has amr stage 3 rev box and 1.5in snorkle. the carb is rebuilt but the jets are stock. It Backfires. Questions
1. Is 1.5in snorkle to small do i need a 2in.
2. What size jets should i run
3.What should the valve clearence be
4. Should i just buy a aftermarket pipe
Old 06-02-2011, 08:36 PM
lightninboy's Avatar
Hmm. I don't really see the point of souping up a Kodiak 450, but it must make somebody happy to do it.
Old 06-03-2011, 09:36 PM
benks's Avatar
your bike is sucking in more air with the k&n but same amount of fuel with stock carb jets, on top of the fact that every atv comes leaned out from japan to begin with to pass tight emmissions, your bike will be running running lean, buy a jet kit from dynojet, the install instructions are easy enough for anyone to follow
use the largest jet in the dynojet kit, usually does the trick, if your snorkel was to small you would be running rich to begin with due to lack of air, take it off your box, rev the bike up see if its any different, if not, its fine
lightninboy
05-16-2021 09:52 PM
txpedsrt1
02-03-2017 08:07 PM
Desimation2k8
07-17-2015 12:37 AM
RedRancher
07-10-2015 06:36 PM
Quick Reply: kodiak 450 problems HELP
