2004 Yamaha Warrior 350
I have a 2004 yamaha warrior 350. I'm having issues with the start button. I've went as far as replacing the start light kill switch assembly, also, the starter relay solenoid and checked the fuse by the battery. Put a new battery in the quad. Still will not start by the push button.
Please help with any suggestions on what to do next...
Note: It will turn over and start by jump firing with a screwdriver off the solenoid relay.
Just a thought, do the neutral light and headlights work before you get the bike running? If not, it may be that you have connected the solenoid up backwards, not sure about the Warrior, but most Yam solenoids have B for battery on one big terminal and M for Motor on t'other. Get em wrong and nothing electrical works until you get the bike started.
tbaws
06-04-2007 06:42 PM
