95 wolverine wont start
Ignition timing is fixed to the T mark, if the piston agrees with the T mark ignition timing has to be right. If the piston shows T mark to be wrong, the flywheel key has sheared. Remove flywheel and fit a new key. Check this first as if you set the valves to the T mark and the T mark is wrong, you are setting the valve timing wrong too.
#15
yes everything went in right those I know how to do top to bottom but I went 2 and a half turns
