YTM crankshaft bearing removal
Old Jul 8, 2020 | 01:09 PM
iceman1465's Avatar
Default YTM crankshaft bearing removal
Hello, have a 84 YTM that I would like to put new crankshaft bearings on. According to a manual it says that if there were to be any damage to the cam chain sprocket that the half of the crankshaft its on would need to be replaced. Can I not press this gear off the crank to replace the bearing? I guess I am not be seeing a reason as to why it wouldn't press off. Any input would be great, Thanks!
Old Jul 12, 2020 | 12:19 PM
iceman1465's Avatar
bump
Old Jul 15, 2020 | 01:46 AM
If the bearing is shot, you will have to try, however if the book says the cam sprocket can't be removed, there will be a reason. Probably no way it will come off without it being destroyed. If the bearing "aint broke, don't fix it."
saint650
May 22, 2012 06:34 AM
saint650
May 22, 2012 06:22 AM
tolowfoshow
Oct 26, 2009 01:04 PM
dakotav8
Oct 6, 2009 04:41 PM
dooho
Mar 19, 2005 06:38 PM
