Brakes
Old Dec 25, 2021 | 05:36 PM
DickB's Avatar
Unhappy Brakes
2002 Bear Tracker 250 Left brake handle is limp. Ordered a new OEM cable and installed it. I depress the brake handle and it stays depressed (brake light on). I adjusted it until the spring was tight, with no more adjustment left, results were the same. Though I triple checked the part and part numbers, it almost seems like the cable is too long. All other brakes and cables work fine. Input please!
Old Dec 26, 2021 | 03:19 AM
The lever on the cam in the brake backplate can be moved onto a different spline, your lever is on the wrong spline. Also cams seize in the backplate, check it moves freely and free it if it doesn't.
Old Dec 26, 2021 | 09:09 PM
DickB's Avatar
Thanks, Merryman. I didn't realize the spline was adjustable. It's my first ATV and I'm sort of learning as I go. I'm 73 and the main reason I got it was to drag deer out of the woods. I just can't do it the old-fashioned way anymore. I adjusted the spline today but didn't move it quite far enough. Will repeat it tomorrow and that should do it. I really appreciate your help. It sure beats the hell out of taking it to a dealer. PS the cam is moving freely.
DickB
Utility ATVs
Dec 26, 2021 10:25 PM
Tramont
1) Engine problems..
Dec 5, 2010 11:07 PM
WAATV
Apr 18, 2007 06:25 PM
bones01
Mar 27, 2005 12:53 AM
blasterkid200cc
Feb 21, 2005 03:31 PM
