1990 Yamaha big bear 350 4x4 ticking noise?
Old Mar 6, 2022 | 02:24 PM
derikthehunter's Avatar
Default 1990 Yamaha big bear 350 4x4 ticking noise?
So my 1990 big bear 350 is making a semi loud ticking noise. Sounds like the valves. Last night I did a valve adjustment, and it seemed to help just a little. Still a ticking noise. Is this normal for this particular ATV? Some things I have read is that ticking noise is fine, just how the machine is. I have heard the saying, "noisy valves are happy valves" but not sure how noisy is good or bad haha. I know a video or at least a recording of the noise would be more helpful and can post that later if needed. Any advice or help would be appreciated thanks!
Old Mar 7, 2022 | 01:56 AM
The valves on most overhead cam ATVs usually make a bit of noise but who can say how much is excessive? Reasons are usually worn cam followers and/or cam, but slack cam chain, worn rocker pivots, or a loose valve seat, are all possibilities, as is piston slap, though this is faster and tends to lessen as you rev and as the engine warms.
Old Mar 7, 2022 | 07:35 PM
Thanks for the reply. Yeah it seems to stay constant and doesn't have a clanking or slapping sound. Just a clicking/ticking that goes with the rpm of the engine. Here is a video of it running. Sorry for the quality. If you listen carefully past all the engine noise you can hear it. Especially after releasing throttle back down to an idle
File Type: mov
Last edited by derikthehunter; Mar 7, 2022 at 08:00 PM. Reason: didnt upload attatchment
Bernhard
Jan 15, 2015 11:42 AM
Ithy
Dec 3, 2008 09:19 PM
beagles
Apr 25, 2005 01:52 AM
02bigbear4x400
Aug 18, 2002 03:42 PM
350BigBear
Jul 11, 2000 10:18 PM
