When I run my quad full throttle it spits crankcase oil from the breather into the airbox, the dealer says it's
I've got a 660 grizz. When I run it full throttle I will find about 2oz. of oil in my airbox. The dealer told me it's normal.
Oil level was not over full.
It is engine oil from the breather.
It makes a big mess and probably sucks oil through the airfilter washing dirt and oil into the engine.
This only happens at full throttle.
Have you guys seen this?
HAPPY-EASTER, RIDE-ON!!!
You are too full on oil, it only takes a little extra to get blown into the air box.My Wolverine will do it if I fill to manufacturers recommendations. Try it a couple of ounces less,if it ends up in the air box, then it was too full to begin with. I also have the rear end spit lube out the vent tube if I fill it up to the fill hole, like the book says. Seems to me they didn't run them full throttle at these levels at the factory,or they would see the blow out. Been running mine just under the recommended level for years, no problems. let the motor tell you want it needs, if it spits it out,its just too full.
RedRancher
06-13-2015 10:08 AM
