2003 450 kodiak cut's out in reverse
Old Jan 6, 2003 | 10:07 PM
quadwarrior02's Avatar
Default 2003 450 kodiak cut's out in reverse
dude on my freinds new 450 kodiak the reverse would sometimes not work. maybe the diff. lock was on or something but everytime he put it into reverse it would like shake and studder and would not work
02 warrior
Old Jan 7, 2003 | 12:04 AM
RealtreeGriz's Avatar
I'd take that back to the dealer before his warranty goes out.
Old Apr 7, 2024 | 11:08 AM
ctravers's Avatar
how did you resolve this? My 2006 is doing the same cutout in reverse.
Old Apr 8, 2024 | 02:17 AM
If it only cuts out when you put it into reverse, the CDI must be getting a signal from the reverse light wire to tell it that it is in reverse, so disconnect that wire to the CDI and it won't get the signal. The rev limiter for reverse won't work either, but some makes of bike don't have one anyway. It could be a sign that your CDI is faulty but, if a simple disconnection of the reverse wire works, I would accept that as a fix. Worth checking the charge rate at the battery when the engine is revved, as overcharging (over 15v) can produce strange CDI symptoms.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Hw00d
Sep 10, 2015 08:53 AM
poutlaw525
Sep 9, 2015 03:19 AM
