back fire caused carb boots to blow off raptor-is there a better boot set-up for raptor?
Old Jan 19, 2003 | 06:44 PM
duneittilludie's Avatar
Default back fire caused carb boots to blow off raptor-is there a better boot set-up for raptor?
well today i was about 3 or 4 miles from the staging area at florence oregon on the dunes and my carb boots came partially off which of course made it impossible to start until i put them back on.i was wondering if anyone makes a aftermarket set-up for the raptor that replaces the stock carb boots as they just look like they are not that secure to begin with.the boots came off after a slight backfire so i can only imagine what would happen if it really backfired.if you have experienced this and have found a solution i would like to hear about it.
Old Jan 19, 2003 | 06:49 PM
DollarBillz's Avatar
man i had to take that little spacer out so i could tighten them down more
Old Jan 19, 2003 | 06:56 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I would have kept the spacer in, but instead of complete removal slightly grind the spacer down for a tighter fit.
Mine have not popped off yet. I thought there was a redesign somewhere in the run, in 2001.
Old Jan 19, 2003 | 07:13 PM
yamaha4life's Avatar
i just put mine back on an 02 today same setup as 01 i already had the spacers taken out
on my 01 i took the yammy clamps off and put true hose clamps on it worked they didnt come
off the just blew the boot in half
there is an ad in dirtwheels for banshee boot come in different colors, so i called and they said
they were in the works for a raptor set ill try to find the company
Old Jan 19, 2003 | 07:24 PM
i found it www.uppracing.com they dont advertise them but when i called
them a while back they said they were working on them???
Old Jan 19, 2003 | 07:49 PM
thanks for the ideas .i think i will try regular hose clamps because it seems like they will be more secure than the stock ones.i have to add that this forum is a very valuable resource for info on anything related to quads and i for one really appreciate it .thanks again [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 20, 2003 | 12:07 AM
raptornz's Avatar
You have the very common lean down low situation. (backfire through carbs)
1. Fix by opening up the fuel screws under the front of the carbs (1/4 turn at a time) on both sides.
Screws should be around 2.5 - 3 turns out from seated position
2. Get the next size up in pilot jets. (standard are 22.5). They go in increments of 2.5 so try 25 pilot jets.
3. Increase the idle.
You don't need the 02 boots, just put on hose clamps you mentioned, they fit just right.....
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
buckshit
Sep 24, 2015 08:49 PM
DOAinNY
Jun 11, 2015 10:34 PM
Steven Bandemer
May 27, 2015 07:39 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
