660, 672, 686 or 727
Old 02-26-2003, 10:31 PM
14mins's Avatar
Default 660, 672, 686 or 727
If you were going to build a motor which size would you chose? If you were going for max hp what would you chose? For those that have gone to 727 why run pump gas?
Old 02-26-2003, 10:38 PM
Ernie660R's Avatar
It is hard to say, all of those combinations work well. I guess it would have to be the lightest rotating assembly with the most compression.
Or the most NOS or turbo boost!!!
Old 02-26-2003, 10:52 PM
alljuice's Avatar
I would go 686 lighter piston and revs faster.
Old 02-26-2003, 11:20 PM
JakalWarrior's Avatar
I would put the biggest sleeve I could get into it, then stroke it down to 600. Install all lightweight guts, then set it up to make peak power at 12000 rpms on alcy with possibly a turbo. Now obviously I dont know if any of that is possible because I dont play with raptor engines, but it carries over my general likes, short stroke, and lots O top end.
Old 02-26-2003, 11:24 PM
66oDisturbed's Avatar
a 727 on alky......oh Mr craycraft...i want one...i got cash!!!
Old 02-26-2003, 11:32 PM
TriRap's Avatar
I've stayed with a 686 not to replace the sleeve. I have had problems with water and oil mixing in other bikes after replacing a sleeve.
Old 02-27-2003, 12:57 PM
icecleric's Avatar
Who does the head porting? Come on post the link so we can check it out. I am also looking at some of the same mods and also looking at a few cerimic/polymer coatings for pistons. I am also looking at a lightweight balanced engine with much better breathing.
Here is a link to a coating a i am considering.
http://www.polydyn.com/hpec.htm
Old 02-27-2003, 01:03 PM
TheRaptorMan's Avatar
I think I may follow in suit with the Dodge Tomahawk concept bike...
Get either a 400 small or 454 big block and bolt it up to the frame... dont think the tranny would hold up though.... may have to think about this one for a while [img]i/expressions/face-icon-small-happy.gif[/img] LOL
Old 02-27-2003, 01:58 PM
garyc660R's Avatar
Given proper buildup with respect too bore and stroke....the larger engine will always make more power.
