no power for starter?
Old May 12, 2003 | 03:02 PM
warrior86's Avatar
Default no power for starter?
well two weeks ago i decided to start up my warrior cause i put it up for sale and all. Hit the button...nothin. i jump started it and it started up. After idling for 2 minutes it stalled but it didnt make enough power to have the battery start it i guess. This weekend, i rode it for a good ten minutes after push starting it and it barely could crank the engine. What do u guys think is wrong. Needs a new battery, alternator or the equivalent, or what? it runs fine. Does anybody know a test i can do to diagnose the problem so im not replacing things that arent broken?
thanks for the help. Warrior86
Old May 12, 2003 | 04:37 PM
raptor03's Avatar
check the battery and the fuses,mine was deade than a doornail( the fuse),no activity in the bike what so ever,changed the blown fuse and it started right up,scared the crap out of me..
Old May 12, 2003 | 04:50 PM
Guest
Guest
Posts: n/a
check the battery fluid level first. Then check all of your connections. If all of those are ok and its not a fuse or something in that area and the battery has power, then well it may be the starter itself, before you try to start it up again, take the starter off, what is shot is the $2 rubber seal. It is letting oil into the starter and shorting it out. If youre lucky you may be able to salvage it, luckily I seem to be good at electronics and have a lot of materials and tools to help and I salvaged it, I didnt think it would work but it did. Anyway check all of this and see what happens,
Patrick
Old May 12, 2003 | 04:51 PM
warrior86's Avatar
well thats the thing...if i ride it for a couple of minutes, turn it off, then try to start it again. Its not completely dead. The starter just gives a super weak crank. Instead of chum chum chum chum, its chhhuuuummmm.......chuuuummmm......chaa...then just goes dead. Could this be related to the fact that ive been starting it by sparking the relay instead of using starter button because the starter button hasnt been working? thanks
Old May 12, 2003 | 04:59 PM
Guest
Guest
Posts: n/a
if it goes from a fully charged battery and then gets worse and worse, like a longer chug, sounding like its harder to push the motor over. Then it is the starter,
Patrick
Old May 12, 2003 | 08:07 PM
warrior86's Avatar
but i dont know if the battery is charging. I drive it for ten minutes and the starter gets a little power but not enough to start the engine.
Old May 12, 2003 | 09:27 PM
Blksnshn's Avatar
if you take the battery out and bring it to autozone they will check it for free, good place to start.
Old May 12, 2003 | 09:38 PM
MojaveRider250's Avatar
it might be ur relay or coil that it brocken the little round piece near ur fuses. or the water level in your battery or something is gone. i dont think its the starter if it is you will proabaly need new brushes.
Old May 12, 2003 | 09:43 PM
warrior86's Avatar
well i know where the relay is. Ill replace that since i have a spare anyway. Ill give the coil a check too. thanks
Reactant
Mar 30, 2022 02:08 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
Chuck188
Jul 17, 2015 02:45 PM
tweeder
Jul 5, 2015 01:57 PM
