2002 Polaris Sportsman 90 Carb leaking fuel
Old 06-27-2012, 01:22 PM
Baldwin Buck's Avatar
Default 2002 Polaris Sportsman 90 Carb leaking fuel
I have a 2002 sportsman 90 that wont stop leaking fuel out of the bowl over flow tube. There is a constant drip of fuel, even with the fuel shut off valve turned off. I have gone so far as to the let the machine run with the gas valve off till it stales out.
I pulled the carb and had it cleaned up by a buddy. He does a really nice job. Thought we had it fixed and that night, DRIP DRIP DRIP
I am now starting to look for a rebuild kit thinking i need to replace the seat and needle assy. But every where i look, most places want over $35 for that assembly alone. And i cant seem to find a rebuild kit for that Mikuni carb.
Can anyone point me in a direction on where to locate a rebuild it please?
Also, has anyone had this problem with their sportsman 90?
thanks for your help
Old 06-27-2012, 01:38 PM
Parts for the little Taiwan and South Korean atv's can get expensive. This is the cheapest I've found so far. It does change part numbers to #0451699 but you can use either one. Also you might check in the Chinese section about finding cheaper parts places. You could have a leaking fuel shut off valve also.0450895 NEEDLE VALVE & SEAT ASM. $32.94
OPT
Old 06-27-2012, 01:50 PM
OPT,
thanks for the link to the cheaper parts. I really appreciate the help.
i sure hope that is the problem. I hate to keep dumping $$$$ on the carb. And i sure dont want to dump $300 on a new OEM carb.
If anyone has had this same problem, please let me know. The bike is in great shape and runs awesome. but i hate to dump that much into it when i only paid $400 for the entire bike. But, my 3 sons love to ride it..................
is there an alternative carb out there that will work and is cheaper to buy and maintain?
skittero
35
03-01-2019 12:39 AM
neilbedwell
11-10-2018 11:02 AM
gfl0224
06-27-2015 06:52 PM
DOAinNY
06-11-2015 10:34 PM
Dakosk
06-06-2015 05:37 PM
Quick Reply: 2002 Polaris Sportsman 90 Carb leaking fuel
