Ramp Storage on Trailer...
Old 11-11-2013, 01:45 PM
dlucky_0803's Avatar
Default Ramp Storage on Trailer...
Hey guys,
I bought this cheap deck over 6'x8' trailer that my father-in-law and I use to haul both of our wheelers on. We side load them using some fold in half ramps. The ramps have a slight curve in them. I'm trying to figure out a way to mount/secure the ramps while in travel. I have been just putting them in my tow vehicle, but it would be nice to mount them somewhere on the trailer itself. Any ideas?
Attached Thumbnails Ramp Storage on Trailer...-20131111_120358.jpg   Ramp Storage on Trailer...-20131111_120421.jpg   Ramp Storage on Trailer...-20131111_120434.jpg
Old 11-11-2013, 03:12 PM
rider77's Avatar
Weld up a couple brackets so the ramps slide in under the trailer on either side of the axle would be my suggestion. That way they are out of the way and easily locked up to prevent theft
Old 11-11-2013, 07:31 PM
user493's Avatar
Moto Psycho
The only thing I thought of so far is to put large bolts through the deck with wing nuts to hold them down. Or just strap them down with ratchet straps, but there are better ways.
Old 11-14-2013, 10:01 AM
TLC's Avatar
TLC
TLC is offline
lay the ramps along side the ATV on and tie them to the Machine.
For theft, park the truck on top off the ramps when your out riding. (Only works for steel ramps not aluminium)
Old 11-15-2013, 09:53 PM
jgar's Avatar
If you can do some fab work. Mount a lockable diamond plate truck tool box over the tongue in front of the trailer deck.
Old 02-15-2014, 03:27 PM
patvetzal's Avatar
I just slide my ramps under my quad. Being homemade, most people wouldn't want them. If you worry about such things then 3' of chain and a padlock will work.
Old 02-15-2014, 06:28 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
well- I mounted mine between the wheel wells and the rack but that doesn't seem like an option for you.
I would weld a bracket on the sides where you could hang the ramps-
Attached Thumbnails Ramp Storage on Trailer...-20140202_125019.jpg   Ramp Storage on Trailer...-20140202_125203.jpg   Ramp Storage on Trailer...-20140202_125405.jpg
Old 02-15-2014, 06:35 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I did this too, when I was building my trailer. I built a slide-out rear ramp. (unfinished in the pics)
Then when I welded a new axle under it- turned out the bed sat 8" lower on the new axle and I was scraping the uneven road because the ramp was too low. I had to cut it all off
Attached Thumbnails Ramp Storage on Trailer...-img_1061.jpg   Ramp Storage on Trailer...-ramp-2-.jpg   Ramp Storage on Trailer...-ramp-1-.jpg
Irishman301
09-23-2015 01:47 PM
awer1968
09-08-2015 11:02 AM
RticKwad
07-21-2015 03:00 PM
Quick Reply: Ramp Storage on Trailer...
