Yamoto 150cc Review
#471
Originally posted by: Davide
The Max load is 210lbs, I'm about 230, would I put too much strain to the motor
and or frame? I’m not planning to use it for jumps, just normal trail riding
at my cottage.
at my cottage.
#472
at my cottage.
at my cottage.
#474
Ok, its probably fine then, thanks.
Are the foot pegs solid if you were to stand on them?
#476
I finally fixed the spark problem I was having. It was the electronic module attached to the stator. Had to replace the stator and the module. It did the trick though.
The foot pegs are flimsy. I welded a piece of steel from the foot peg to the frame on each side to make them more sturdy.
#477
I have the yamoto 110 also, to increase power remove the exhaust baffle.
It will make it sound better and increase power, and it's very easy, just a couple of screws in the rear of the exhaust pipe.
Also, check the air intake, they come with a restrictor. Open this up for all the air flow possible.
As for as the gears, I agree they are terrible.
I've had almost every screw, bolt, nut, work loose. Double check everything and use lock tight. I had my motor mount bolt end up missing! The battery constantly goes dead, the turn radius is not too good, but that's ok, my 8 year old rides it and I dont want him flipping over.
For him it works great. I've had problems with the rear drum cheap brakes, but they were easy to replace and parts have not been a problem to find or get.
The gears are too hard for him to shift, so he just rides around in 3rd gear all the time. A hand shifter made this very easy to shift for him, but he didnt like how it looked and took it off.
Weld on a rear arm to the gear shift and they can shift up and down easily by stepping on the shifter back or front [img]i/expressions/face-icon-small-smile.gif[/img]
#479
Check your local Yamaha shop. The heel/toe kick off the PW80 may work on the Yamoto. I know it is hard for some to believe or swallow, but Yamoto is just as much a knock-off as any other Chinese brand. A lot of theirs is either Yamaha or Kawasaki.
#480
