Yamoto 150cc Review
Old May 25, 2005 | 08:32 AM
  #411
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Yamoto 150cc Review
Thanks for the update Knarf.
Old May 26, 2005 | 12:19 AM
  #412
crocstar23's Avatar
I have been reading all the posts and think the Yamoto would be a good atv for my son. Was wandering if anyone knew of a dealership in middle or east Tennessee. Thanks.
Old May 26, 2005 | 09:26 AM
  #413
Knarf's Avatar
I am pretty sure there is a guy over there. I will check on it for you. Knarf
Old May 27, 2005 | 01:37 PM
  #414
crocstar23's Avatar
Thanks ...Id appreciate it.
Old May 31, 2005 | 09:59 AM
  #415
KTM Patrol
Former Chinese POW!
We took the yamoto 150 out for a ride monday and it performed great. The engine performed well on a couple of hill climbs and we clocked it again for top speed. Still 32 mph even with the uni filter and the answer muffler, not to mention the new wheel bearings. Oh well, the wife says it is fast enough for her.
Old Jun 1, 2005 | 01:13 PM
  #416
Kell's Avatar
Haven't been here in a long time but here goes:
as far as replacing the air filter with a k&n and it not running like it used to, it sounds to me like it needs to be re-jetted (richer) because of the increased airflow (assuming you are no longer running the stock box). Check your plug, like someone said, try turning your air fuel mixture screw out some more.
Mywifes quad, check this site out for a few mods on this style engine (GY6 clone), I would like to try advancing the timing by elongating the holes on the pulse generator like they have suggested. Although I already have trouble turning the engine over when it is really hot due to the bumped up compression. Would like to modify my transmission also by either lightening the rollers or increasing spring pressure on the driven side of the CVT.
GY6 timing mods
for those who don't know the 150cc is a licensed clone of the honda GY6 scooter engine.
also, tried the NGK iridium plug with some good results, may be worth $10 if you need a plug anyway.
kell
Old Jun 1, 2005 | 05:22 PM
  #417
KTM Patrol
Former Chinese POW!
Originally posted by: Kell
Haven't been here in a long time but here goes...
GY6 timing mods
kell
Good to hear from you kell, Thanks for the link to the scooter page. I will read that later and consider advancing the timing on my wifes quad. I dont know why, she thinks it is fast enough. I would just like to liven the engine up a bit. I thought about advancing the cam one tooth. But like i say the wife is happy with it now.
Old Jun 1, 2005 | 05:45 PM
  #418
Kell's Avatar
Already tried that, (advancing the cam 1 tooth) what a dog it turned into!
Milling my head retarded my cam 1/2 tooth so I thought I would try advancing it and figured out quick that was the wrong direction to go! I had heard retarding it would help low end and advancing it would help top end. Since I had plenty of low end, I tried it, all in the name of science of course.
as far as the Iridium, I timed it and it consistently came out to be .3 seconds (3 tenths of a second) faster on my little drag strip. The gain was at the lower rpm's. Not much faster but noticeable. probably a bike length at full speed if you were drag racing.
Old Jun 1, 2005 | 07:12 PM
  #419
Knarf's Avatar
Crocstar, I should have some info for you soon. I have not forgotten. Knarf
Old Jun 1, 2005 | 07:35 PM
  #420
Knarf's Avatar
Crocstar23, You can check with Clark's Power Sports in Harriman, TN 37748. I called him and spoke with him. Tell him Lake Norman ATV sent you, his name is Bobby Clark, Phone 865-742-7066 Good Luck, let me know how it works out. Knarf
