SUNL 70 won't start need help please
Old Jul 31, 2010 | 04:53 PM
Jaster94's Avatar
i've never used a wire brush when cleaning a carb. i use the carb cleaner, an old toothbrush(battery operated or manual), and an oxy/acetylene torch tip cleaners to get inside. but i use the smallest i can so as to not score the jets or any orifices. and just a tad of air also.
Old Jul 31, 2010 | 05:12 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Yes you need to see light thru the jets and also thru the side of the pilot jet and main jet holder... I wouldnt use a wire brush to clean jets unless you are trying to push 1 strand of wire thru the hole.. then use the carb cleaner and compressed air..
Old Jul 31, 2010 | 07:29 PM
Alec_Logan's Avatar
ok so the main jet should be hollow all the way through to the screw head?
Old Jul 31, 2010 | 07:30 PM
Alec_Logan's Avatar
an yeah just using one strand to go thru the holes, but i can't get it through the entire screw at all, it seems tohave something lodged in it
Old Aug 1, 2010 | 09:00 AM
  #15
KTM Patrol
Former Chinese POW!
Try soaking the jets in carb cleaner... baby food jars work well for this.. after 12-24 hrs try poking the wire thru the middle...
Old Nov 5, 2010 | 03:55 PM
  #16
Big Es's Avatar
Hi new here I have my sons sunl 90 cc I did same cleaned with carb cleaner and all jets clean new fuel filter and is in the right flow but I can not get fuel to carb I removed fuel bowl screw and was pressurizing fuel tank and can not get fuel to it any ideas??
Old Nov 6, 2010 | 10:37 PM
  #17
LynnEdwards's Avatar
Electrical Expert
I have no experience with your quad, so take my advice with a grain of salt.
Disconnect the fuel supply hose right at the carburetor, then see if fuel comes out freely. That separates wether the problem is in the carburetor or on the way up to the fuel tank.
Some quads have vacuum operated fuel shutoff valves such that the fuel from the tank is shut off automatically when the quad is stopped. But if the float bowl goes dry then there is a deadly embrace - the quad won't start because there is no fuel, and no fuel can be delivered because the quad won't start. Look for a fuel shutoff valve with a vacuum hose attached, and if you have one it would have a "prime" setting.
Old Nov 7, 2010 | 06:23 AM
  #18
Big Es's Avatar
Hi thanks but I looked for that no hose no fuel off switch I was thinking of a check valve in the tube the hose goes on but I don't see it. I am buying New carb 25 buck should be good I be leave the fuel inlet is clogged or something.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bigredjeep
Apr 10, 2020 02:55 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
