clutch
Old Mar 25, 2012 | 07:38 PM
Dhunter830's Avatar
Default clutch
The other day i was riding my 4 wheeler and my clutch cable broke, i have pulled the cable as tight as it will go and try and shift it into gear yet it still jumps like im not using the clutch. I believe i may have messed something up inside the transmission. Any tips?
Old Apr 12, 2012 | 07:53 PM
Jaster94's Avatar
go ahead and replace the cable and then try it again. then let's go from there...
Old Apr 15, 2012 | 09:34 AM
Dhunter830's Avatar
I've already tried that
Old Apr 15, 2012 | 07:26 PM
Jaster94's Avatar
you should be able to pop the cover off and check it out to see if you have any physical damage.
Old Apr 15, 2012 | 07:35 PM
Dhunter830's Avatar
i have done that too and from the best i could tell by just looking at it there wasnt any.
Old Apr 15, 2012 | 08:26 PM
Jaster94's Avatar
well, sounds like it's time to pull the clutch. i wouldn't think that your transmission is somehow fouled up. i mean that if you have it in gear and you're riding around and you don't have any clunking happening, your gears are probably fine and not stripped.
i think the clutch replacement will fix you up. you probably didn't want to hear that. i totally understand. i hope i'm wrong and it's something simple. i'll keep looking around in my books/manuals.
Old Apr 16, 2012 | 07:42 PM
Dhunter830's Avatar
well crap
Old Apr 16, 2012 | 10:45 PM
Jaster94's Avatar
you know now i'm wondering if the inside of the clutch fork assembly may be bent. you know, the piece that your cable attaches to but the other end inside? i'm not sure of the technical name of that part, but i am curious if that may have bent when it slammed back to the open position when the cable snapped. i got to dig on this some more to help you out.
Old Apr 18, 2012 | 05:04 PM
Dhunter830's Avatar
alright. when i get some time i"ll pull it apart again and take a closer look at things
Old Apr 23, 2012 | 07:59 PM
Dhunter830's Avatar
i should add that this a taotao ata 250d 4 wheeler (its an off brand chinese 4 wheeler) if that helps with anything. i know their clutches are a little different
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
