Transmission Issue
Old Sep 3, 2014 | 07:57 PM
  #21
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If there is enough material left Id re tap it.. if that doesnt work heli coil is next.
Old Sep 6, 2014 | 08:37 AM
  #22
crusher29's Avatar
I pulled the clutch off and now can see the shift mechanism. I don't see anything bent or broken. I uploaded a pic to my photo album. Am I missing something? It feels like when I shift, the top left sprocket shifts ok but when I push the lever down to go to neutral or reverse, it doesn't move much. If I hold the lever down (back side of shifter), it will go into neutral. Is it something inside the gear box in the engine?
Have to get a helicoil to repair the plug hole but I think I will wait until I can figure the shifting issue.
Old Sep 6, 2014 | 01:00 PM
  #23
KTM Patrol
Former Chinese POW!
Check the tightness of the nut holding the 5 star shifting piece. And also if that star shaped piece is moving completely or slipping under the nut?
It does all look good in the pic.. trouble is more than likely inside if everything that moves when your shifting is tight.
Old Sep 6, 2014 | 04:54 PM
  #24
crusher29's Avatar
Thanks. I will check it out.
COFatboy
May 2, 2020 12:06 AM
greg74
Sep 10, 2019 03:03 PM
cornermike
Aug 10, 2016 06:47 AM
Captjay
Jul 23, 2015 12:33 PM
bikedad3
Jul 2, 2015 02:15 AM
