Relay Clicks on Coolster 125 atv
Old Mar 27, 2018 | 08:44 PM
benrhargis's Avatar
Default Relay Clicks on Coolster 125 atv
I installed a new battery on a Coolster 125 4 wheeler. Went to start it and the relay just clicks. Started fine previous to battery installation. Any idea what the problem is and what caused it?
Old Mar 28, 2018 | 02:31 AM
Check your new battery has some charge in it. I have known new ones to be flat. If that is OK, check you have clean, tight battery connections. If it still just clicks, I go for the 12v test lamp method of checking, one wire from lamp to battery earth, the other to thick wire on solenoid that goes to starter motor. Ignition on, press start button, if the lamp lights but starter doesn't turn, you have a faulty starter. If it clicks but the lamp doesn't light, you have a faulty solenoid.
Old Mar 28, 2018 | 09:38 PM
benrhargis's Avatar
Not familiar with the test lamp method. Don't know much about these. I took a pair of pliers and put each end on the positive and negative terminals on solenoid and the brake lights went off. It didn't didn't try to turn over or anything. It barely even sparked. Not sure. Any help is appreciated. Like I said, I'm new to all this and don't really have much knowledge of mechanics. The atv is practically new though. Just got in December for my son and haven't really rode it much.
Old Mar 28, 2018 | 09:39 PM
benrhargis's Avatar
And it's more of a buzz that the solenoid makes than a click.
Old Mar 29, 2018 | 01:52 AM
Flat battery.
Tattoomike
3) General Discussions..
Mar 17, 2018 10:11 AM
NEWBE11
Jun 28, 2017 10:30 AM
b_ryan1978
Jul 5, 2014 06:54 AM
Pmerkich
1) Engine problems..
Apr 13, 2014 08:26 AM
Chaser2178
May 17, 2012 02:45 PM
