White smoke
Old Jun 18, 2019 | 09:19 PM
Booker140's Avatar
Default White smoke
Hi everyone,
I bought my kids some used chinese 110cc atv that I was told work but didnt. I have one working but after running for 20min or more i noticed white smoke from the engine. Just sitting idling it was smoking. I put new fuel, new fuel lines, new carb, new spark plug. Online everything says white smoke is a rad/coolant issue. However these chinese atv dont appear to have a rad to leak coolant. Anyone have any ideas what is wrong?
Thanks in advance,
Booker
Old Jun 19, 2019 | 02:10 AM
Vehicles with air cooled engines need to be moving in order to keep cool, unless they have a fan cooling system. Don't leave one sat idling. Find out where the smoke is coming from. My guess would be an oil leak onto a hot part, like the exhaust.
Old Jun 19, 2019 | 07:20 AM
Booker140's Avatar
Thanks for the reply. Ill take a look when i get a chance.
Booker
Old Jun 19, 2019 | 09:02 AM
Zrock's Avatar
Super Quad Patrol
how much fuel have you run since you got it? it may just be burning the varnish and crap thats mixing in from the tank. Your not mixing your fuel right? What is the compression on the engine? it may need a little freshening up with new cyl rings they may be letting a bit of oil past
Old Jun 19, 2019 | 04:31 PM
Booker140's Avatar
Havent run much fuel through it. Only had it running 20 min maybe 30 min. It is used. And dont know about compression. A friend has also said ma6be a bit of oil is leaking out and burning. Going to check that next.
Booker
Old Jul 4, 2019 | 11:54 AM
Booker140's Avatar
Ive read white smoke is coolant burning. I ha ent been able to find a rad on these atv. Im being told them might be air cooled. I have ripped the atvs apart all accept the motor and the piece between the motor and carb. Which is also where the exhaust connects and that connection is where the smoke comes from. Im not mixing. Its straight fresh gas. Would i get this white smoke if they over filled the oil? And burning oil?
BiffBlaster
17
Dec 15, 2002 09:46 PM
Kodiak01
Nov 16, 2002 10:45 AM
BiffBlaster
Sep 16, 2002 04:45 PM
92LT
Oct 21, 2001 12:37 PM
wahoo
Oct 19, 2000 12:12 PM
