New LT80 Loading Up
Old Feb 14, 2004 | 04:34 PM
MyKidsMechanic's Avatar
Default New LT80 Loading Up
I just purchased a new 2004 LT80 for my son. We removed the factory restrictors, but we can't seem to get it to clean out. It loads up and sputters around like the plug is fouled, but I already checked that. Plus when you slow down and stop, it won't idle for nothing. This is very frustrating for an 8 year-old. Any suggestions would be appreciated. I am probably going to take it back to the dealer next weekend to have him check it over. Thanks
Old Feb 14, 2004 | 11:00 PM
xxxracerxxx's Avatar
do you mean you took out the factory air restrictors to the engine if so it should run lean with there being more air to the motor so there must be something eles wrong
Old Feb 15, 2004 | 07:24 PM
LT80's Avatar
LT80 Expert
Idling: Did you try the idle adjustment? (only screw on the carb)
You did remove both the carb restrictor under the slide AND the exhaust restrictor from the cyl/pipe area.
Another thing: the spark plug cap sometimes falls off and dont contact the plug properly.
Old Feb 20, 2004 | 02:45 PM
Quad4Fun's Avatar
LT80,
If you remove both of the restrictors, is there anything else you need to do? Or can you just remove them and leave it at that?
I got my kids a '04 lt 80, and will probably bug you with some more questions at some point. I'm trying to learn all I can by reading through all these different threads first.
Thanks a Bunch
Old Feb 20, 2004 | 03:53 PM
2Gordons's Avatar
Sometimes the dealer will add premix to the gas in the tank for the "break-in" period even though there is an oil injector on it. Try draining the tank, adding fresh gas, new plug, and see if that works.
Old Feb 21, 2004 | 08:11 AM
fastfredy's Avatar
put some duct tape over the top of the spark plug cap, the cap sometimes likes to pop lose.
Old Feb 21, 2004 | 05:48 PM
LT80's Avatar
LT80 Expert
Good ideas here [img]i/expressions/face-icon-small-smile.gif[/img]
There should be nothing else to do after removing the restrictors.
ALL questions welcomed!! Bug away!!!! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 21, 2004 | 06:10 PM
Quad4Fun's Avatar
Went to remove the restrictors today, and they were already gone. Dealer must have removed them.
I opend the throttle up for my daughter today. That little thing scoots with her on it, vs my fat butt on it [img]i/expressions/face-icon-small-happy.gif[/img]
Looking forward to putting the A-arm extensions on, then figuring out what to do to the back.
Dewhound
Apr 20, 2017 02:25 PM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
