prairie
Old Nov 14, 2004 | 07:30 PM
6513's Avatar
Default prairie
how fast does it go?
Old Nov 14, 2004 | 07:38 PM
vtwinriot's Avatar
Default prairie
Which one? 300, 360, 400, 650, 700?
My 700 ran 69 when stock........ not enough room to try it now.
Old Nov 14, 2004 | 08:31 PM
6513's Avatar
Default prairie
ya thats wat i meant
thanx
Old Nov 15, 2004 | 01:26 AM
cc1999's Avatar
Default prairie
If you can get the power output up high enough the clutch will run out around 75mph. My STP700 will run out at around 75mph on the dyno, however only my modded 800 can run the clutch out all the way in the real world. If you have the power you can get a little more with taller tires, and there are some clutch mods combined with some parts from the V-force, 80+ mph is possable, but I will say I have had my 800 up to 78mph with the use of taller tires than stock and it gets a little floaty up there, I don't know if it is worth the money to me to get the other 4 or 5 mph.
Old Nov 16, 2004 | 11:40 AM
maddog56's Avatar
Default prairie
Originally posted by: housefullofkawi
i dont believe you
Which part? 69 stock or cc1999's info?
69 stock is pretty generous, I get 62.
As far as cc, his info is all pretty much dead on. You can clutch for whatever speed you want, alltoys had 98mph. But we all know why thats a bad idea.
Old Nov 16, 2004 | 04:40 PM
6513's Avatar
Default prairie
how fast would a 300 go? (stock)
thanks
Old Nov 16, 2004 | 04:43 PM
maddog56's Avatar
Default prairie
Bayou 300? Couldnt tell you for sure, probably just south of 60.
Old Nov 16, 2004 | 05:36 PM
newbeatle's Avatar
Default prairie
Our "stock" Prairie 300 will run around the l,ow to mid 40's mph... about the same as the 360's... HOUSE... I'm curious what you don't believe, as well... there is a very large variance in top end speeds between seemingly similar stock quads... it is very possible for the faster ones to reach close to the upper 60's in top speed... mine was a slower one in stock form...( part of the reason for my rebuild )... now I run similar speeds as stated, with my modified 750cc Prairie...
Old Nov 17, 2004 | 10:19 AM
Adirondack's Avatar
Default prairie
On asphalt, I can hit 68 mph, w/ stock tires, on my '03 P650. W/ 26" tires, on a long downhill, I can get a speedo indicated speed of 69 mph (this is w/ dyna CDI), which converts to 71.76 mph. However, I am not sure just how accurate the factory speedo really is.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
