Muffler water Drain plug P650 FAKE???
Old Nov 22, 2004 | 10:32 PM
yamihoo's Avatar
Default Muffler water Drain plug P650 FAKE???
Well when I did the NYROC muff mod, I took out the "drain plug" on the muffler to find there isn't actually a hole under the bolt thread. Anybody else notice this? Is this an "option" a "fake" or what???
Old Nov 22, 2004 | 10:44 PM
yamihoo's Avatar
no, I pounded on it, its steel...in fact I think I might have drilled it out..I'll have to check.
Old Nov 23, 2004 | 12:38 AM
Mobyguzzer's Avatar
I watched a friend drain water out of his p650 muffler with it.
Old Nov 23, 2004 | 08:03 PM
vtwinriot's Avatar
When I took mine out it seemed to be the same way but it turned out to be carbon buildup. It was very hard but did break out with a little persuasion.
Old Nov 23, 2004 | 08:49 PM
Nightryder888's Avatar
how did you guys get that plug out? ive tried every thing short of taking a torch to it
Old Nov 23, 2004 | 11:23 PM
kodiac1's Avatar
I can't get mine out either....I am afraid I am going to booger the thing up so bad I will never get it out.
02 650 camo
Old Nov 24, 2004 | 09:27 AM
yamihoo's Avatar
Mine just came out, I think I soaked it first with WD40 probably. I have to check that again tonight, forgot to see if I can clear that hole again.
Thanks for all the replies! Maybe mine is just plugged with carbon, or a defect.
Old Nov 24, 2004 | 12:35 PM
Grizzjeeper's Avatar
Mine is solid as well, no hole.
Old Nov 24, 2004 | 12:41 PM
MikeyBoyesq's Avatar
Yep, mine was solid too, but its the carbon build up as someone stated above. All I had to do was punch it out with a screwdriver and hammer.
For maintenance reasons, its a good idea from time to time to remove that plug and rev up the motor while in neutral so as to blow out the carbon build up in the muffler.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
slowgsxr97
Mar 18, 2022 03:40 AM
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
Shifts
Jul 3, 2015 07:59 AM
