BELT LIFE
Old Dec 27, 2004 | 07:51 PM
BARBWIRE's Avatar
Default BELT LIFE
JUst out of curiousity, How often do you change your drive belt? Do you typically drive in high or low range? What are your driving habbits?
Old Dec 27, 2004 | 08:08 PM
tuffEnuf's Avatar
Default BELT LIFE
Drive in low range whenever possible. Do not tow or put heavy load on atv CVT in High range. Belt life is dependent on use and keeping belt properly adjusted. You can smoke a belt in an afternoon pulling yur buddies out of mudholes. Typically when belts ar adjusted they last 1000-1500 miles or more. Best way is to do deflection check periodically and shim as required. Change belt when deflection is out of limits or visible damage to belt is noted.
TuffEnuff[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 27, 2004 | 08:11 PM
lewichris's Avatar
Default BELT LIFE
So plow snow in low also?
THanks
Old Dec 27, 2004 | 08:28 PM
tuffEnuf's Avatar
Default BELT LIFE
Lewichris
Definately; Plow in Low. Low will take you as fast as you need to go plus give you plenty torque.[img]i/expressions/face-icon-small-happy.gif[/img]
Tuff
Old Dec 27, 2004 | 08:43 PM
deerchooper's Avatar
Default BELT LIFE
i got 1800 miles out of my factory belt, with checking belt deflection often. i ride in high range all the time. i plow in high range all the time. i go from putting to full bore all day long.
Old Dec 27, 2004 | 11:29 PM
kodiac1's Avatar
Default BELT LIFE
I am on course for 1500 miles and I do keep it in adjustment.That is with a factory belt.
02 650 camo
Old Dec 28, 2004 | 10:41 AM
s2mikey's Avatar
Default BELT LIFE
Here are some good belt tips for ya:
1. Use LOW gear when going 18mph or less. There is NO reason to leave it in high when trudging through mud or on slow trails.
2. Towing, pulling, carrying = LOW gear
3. Avoid too many "launch" starts or burnout attempts
4. Use the brakes to slow the vehicle, don't just rely on engine braking...this takes a good load off the belt.
5. Use brakes when going down steep hills...trust me.
6. If you run 27" or bigger wheels/tires I'd advise you upgrade the suspension or add a lift kit.
I personally have almost 1100 miles on my Brute with 26" c-rims & 589's and the belt is in perfect working order.
Mike
Old Dec 28, 2004 | 06:59 PM
kodiac1's Avatar
Default BELT LIFE
Holy Cow..1100 mile on it already??do you ride it to work?? lol
02 650 camo
Old Dec 29, 2004 | 12:44 AM
Uinthas's Avatar
Default BELT LIFE
02 650 camo
[img]i/expressions/face-icon-small-happy.gif[/img] lol.. Heck yea, there ment to be ridin, my 03' is aproaching 5000 miles!!
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Elkaholic
Sep 6, 2015 02:44 PM
