LT 80 will only run with choke on..need help
Old Apr 29, 2006 | 12:29 AM
billyboys's Avatar
Default LT 80 will only run with choke on..need help
I have pulled the carb apart twice ...and it will only run with choke on..yesterday the bike flooded itself and filled the jug..exhaust and carb with FUELl...
Maybe a busted reed ?
I have cleaned carb and main jet..but i only have air/screw ? or idle screw not sure wich one it is BUT the screw on right side of carb 3/4 of a turn out
NEED HELP PLEASE
Old Apr 29, 2006 | 10:15 AM
LT80's Avatar
LT80 Expert
Welcome to the ATV Connection forums. [img]i/expressions/face-icon-small-smile.gif[/img]
OK, you cleaned the carb but did you remove the pilot jet and clean it? Did you remove the brass needle seat and clean? Did you remove the choke unit and clean?
Doubtful on the broke reed.
The screw on the side is the idle adjustment.
FYI:: Petcock:: In the on position, fuel will run out only when the motor creates vaccum (the line furthest to the back of the carb). In the prime position fuel will run all the time.
We'll go from there. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 29, 2006 | 12:44 PM
billyboys's Avatar
THANKS FOR YOUR HELP I will try that and let you know
GREATLY APPRECIATE YOUR HELP
Old May 1, 2006 | 11:58 AM
sssduane's Avatar
In the prime position fuel will not run all the time, it will run until the bowl is full then the needle and seat should close once the float rise's. So if you filled the jug, its because your needle isn't fuilly seating.
Check for vacuum leaks between the carb and intake.
Old May 2, 2006 | 08:42 AM
LT80's Avatar
LT80 Expert
Well actually, filling the cases is caused by the hydraulic weight of the fuel pushing by what little pressure the float gives. This is why bikes have to have the fuel shut off.[img]i/expressions/face-icon-small-wink.gif[/img]
I explained the petcock operation so he could understand the correct workings of it.
Old May 5, 2006 | 08:19 AM
rheemac's Avatar
had same problem not more than 5 days ago. remove carb. and clean. take jets out of carb. it will work after that. also, no cheap oil!!
Old May 7, 2006 | 06:30 PM
billyboys's Avatar
THANKS FOR YOUR HELP......I cleaned the pilot jet and it runs like new...Pilot was plugged shut ..so i cleaned it with carb cleaner and then blowed it out with an air hose [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 8, 2006 | 12:43 AM
sssduane's Avatar
Glad you got it. Better off then me, I gotta replace my entire jug.
Old May 8, 2006 | 10:26 AM
LT80's Avatar
LT80 Expert
SSS~I was reading your Duinli post. Not sure if you were asking or explaining. [img]i/expressions/face-icon-small-smile.gif[/img]
Why do you need a new jug? No overbore?
Old May 8, 2006 | 11:01 AM
sssduane's Avatar
Give's me a reason open it up a little........
I could bore it, probably get away with honeing and putting in a new ring and pistons but, Why not just throw on a 52 mm jug thats ported etc................[img]i/expressions/face-icon-small-happy.gif[/img]
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
