no spark on 2001 700 sportsman
Old Dec 16, 2008 | 08:05 PM
searoach's Avatar
Default no spark on 2001 700 sportsman
bike sat and had to charge battery back fired and then ran I parked knowing the carb needed cleaning.next day I cleaned carb and put in new fuel.now I have no spark I pulled plug wire and put screw driver in and held next to ground with gap no spark
checked throttle air gap on hand throttle dont know what ealse to do I dont have prints even those will help
thank you for any help
Old Dec 16, 2008 | 08:13 PM
DO you mean 2002 model? If early 700 (02-04) check under front panel,says DUCATI on coil pack,this is the combo coil and cdi unit. I've replaced several,could be your problem. Dealer or other posters can give you stator specs to eliminate stator,or I can get for you at work. Good luck
Old Dec 16, 2008 | 09:11 PM
searoach's Avatar
Yes the front panel says DUCATI on coil pack and the sticker on body cover says 02-01-2002.I dont want to do anything untell I test stator or can get prints
thanks for everything out there O.P.T
Old Dec 18, 2008 | 04:19 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: searoach
thanks for everything out there O.P.T</end quote></div>
If you decide that the coil/cdi is your problem I have a used one in my box of old parts. Let me know.
Jmuddin284
Jan 19, 2026 07:16 AM
Ramman1
Jun 16, 2016 09:07 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
Jul 3, 2015 07:59 AM
