Will i notice a big difference?
Old Apr 19, 2010 | 01:23 PM
maverick11's Avatar
Default Will i notice a big difference?
I put bighorns on my 2006 sportsman 500 efi HO and am considering getting a clutch kit. Will i really see a big difference considering im going to be spending close to 200 bucks if im gonna do it?
Old Apr 19, 2010 | 02:08 PM
switzomatic's Avatar
I run an EPI big tire kit and the low end power/torque is definitely noticed! Well worth losing a bit off the top-end.
Old Apr 20, 2010 | 11:48 AM
maverick11's Avatar
thanks... they are still stock size but it looks like i can bet a clutch kit for stock... how much will i lose off the top end.. how long does it take and how hard are they to install, im no master mechanic but i can figure alot of things out
Old Apr 20, 2010 | 07:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the question is what are you trying to gain in the clutch kit. most put it on for the oversized tires to help offset the power loss form the extra size and weight.
Old Apr 21, 2010 | 07:14 AM
maverick11's Avatar
I would like a little more low end and maybe some in the mid range... i dont open it up to often so i dont mind giving up top speed for more power... but if the stock clutching is the best im gonna get with 26' tires then thats fine.
Old Apr 21, 2010 | 09:32 AM
TLC's Avatar
TLC
If you going to get a clutch kit, Try 26" tires. With 25" tires the stock clutching is fine. Your in low range under 20 mph anyways, cant get more low end grunt then that.
Old Apr 22, 2010 | 05:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might be able to get a little more grunt and a sharper engagement from take off. you could even get a quicker shift out to get at speed a little quicker which all leads to loss of top end speed. most of the kits as i mentioned are to make up for for bigger tires. i just have a primary spring in my bike to help w/ the bigger tires and it works fine for me. now if i take the big tires off and leave the spring in, my bike tends to want to whelie alot easier lol.
Old Apr 22, 2010 | 01:03 PM
maverick11's Avatar
thanks for all the input... i think since im still running stock tire size ill leave the factory clutching for now... i wouldn;t mind being able to pull a wheelie with a 700 pound machine...
Old Apr 22, 2010 | 04:39 PM
Probably a good call. The clutch kit will make it more snappy and you lose 4-5mph off the top end. Definitely not needed if sticking with stock sized tires. If you do go bigger and decide to clutch it the primary is an easy job but the secondary is a pain without the right tool. I did everything on mine except the secondary. Had my dealer install it and they only charged me $35. Brought it in and they had it done in no time.
Bratman2
Aug 6, 2022 01:42 AM
Valder
Nov 28, 2020 07:38 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
rcappie4
Jul 10, 2015 04:54 PM
