04' DS650 won't shift ( neutral switch ?? )
Old Jun 20, 2010 | 01:37 AM
Bombardier_Brad's Avatar
Default 04' DS650 won't shift ( neutral switch ?? )
After sitting for awhile, I desided to break out the DS and hit the creek. When I turned on the key switch, the neutral light did not come on, though I knew it was in neutral. I pulled in the clutch lever and cranked it. After a few attempts it fired up. The neutral light slowly started to glow and showed that it was indeed in neutral. I shifted into first ( as I did the bike jerked a little like the clutch wasn't fully catching ) and slowly crept off. When I tried to shift into second, but no-go.
I'm hoping that i dont have bent shift forks. Could it be the switch? And if so, could i just unhook it, remove it, or whatever - or would i have to replace it.
Also, where the hell is it??
Old Jun 20, 2010 | 05:13 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Look for the wire that runs right in front of your oil filter. Follow it down to the screw, remove it, clean the area real well, replace the screw and ensure that you have it tight.
You should get a slight jerk or surge when you engage from neutral with the clutch lever pulled in. If it's a hard clunk adjust the tension at the lever. Simple fixes to issues that can cause headaches. Let us know if that doesn't work.
Old Jun 30, 2010 | 05:03 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I would suspect a faulty clutch-
Old Jun 30, 2010 | 11:26 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
Wink
the ds is not a boat! Check the cluch cable and make sure it returns it might be sticking and holding the clutch open. the light just tells you the shift drums in the neutral position
I never tried pulling a skier with the ds? hows it work?
Old Jul 7, 2010 | 10:24 PM
ace_mechanic71's Avatar
I would suspect the clutch cable also.
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ScopeZ_
Jul 28, 2015 01:44 AM
sara durrant
Jul 6, 2015 05:32 PM
