belt slipping???
Old Feb 23, 2013 | 08:53 PM
louiecool's Avatar
Default belt slipping???
Can someone please tell me what the symptoms of a bad cvt belt are. please
Old Feb 23, 2013 | 09:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
slipping when in an hard accell, noisey, you can take belt cover off an look at the overall condition,,,Clutch may just need reshimming tho..How many miles is on belt?
Old Feb 24, 2013 | 06:58 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
high rpm while in gear with no movement, maybe slight rubber smell. Pull the cover and inspect the belt- it'll take all of 1hr.
Old Feb 24, 2013 | 07:59 AM
TLC's Avatar
TLC
That,s one sure sign. LOL
Old Feb 24, 2013 | 09:36 PM
louiecool's Avatar
Ok im sure its slipping, will it cause atv to stall at certain mph im gonna get a new belt but what about springs atv has bluemillion miles on it thanks for the replies
Old Feb 24, 2013 | 09:44 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
No. A slipping belt will not cause an engine to stall- hence the "slipping belt"
If the belt was gripping the clutch hard enough to stall the engine, then the belt wouldn't be slipping- but you would have other clutching issues because a cvt clutch in proper mechanical order can't stall the engine-
You should read up on how cvt's work-
Old Feb 24, 2013 | 11:20 PM
louiecool's Avatar
ok thanks for the reply I know the belt is slipping. stall was the wrong word. this is 1999 prairie 400 when accelerating it goes to 22-24 mph and starts to act like its flooded if i return to about half or maybe even three quarter throttle the engine will act normally but it will not accelerate and i m pretty confident its not the carb I saw a thread from several years ago about this very same issue but the solution wasnt posted or at least i cant find it. any help is always appreciated
Old Feb 25, 2013 | 10:25 AM
Loved
Community Favorite
If belt light is on the belt being loose could have flipped the belt switch under cover an maybe in a limp mode..Just look at switch when you remove cover an see if switch in flipped in the off posotion..if is reset...good luck
Old Feb 25, 2013 | 04:42 PM
louiecool's Avatar
thanks I'll look at belt and let you know
Old Feb 25, 2013 | 07:33 PM
louiecool's Avatar
ok took the belt cover off lots of wear mostly wear the ramp weights and moveable sheave mate gonna order some parts Belt looks good to me but I'll get one anyway
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
