my custom made rotopax mounts (pics!)
my new rotopax tanks arrived today- can-am racks suck to mount anything on- universal never work out- so made up some custom brackets this evening
the orientation:
the template:
cutting & grinding into shape (I really need to buy a plasma cutter
polishing:
welding the tank mount on the bracket (didn't want to mess around with nuts & bolts
painting:
brackets bolt on using the original rack mounting bolts; no need to ruin your rack by drilling hole in it for studs!
finished
if anyone would like me to mail them my template (works on all 2012+ outlanders) just ask
the orientation:
the template:
)polishing:
)painting:
finished
thanks jf
very heavy duty- 10 ga steel (just under 1/8" thick!) and thankfully rotopax also uses mild steel for their mounts- so welding was a no-brainer vs. drilling the rack trying to accommodate the mounting hardware.
the universal rotopax mounts are really useless on these new outlander racks- the racks have so many cut-outs and slants, that finding an asymmetrical spot to bolt the rotopax mount to is impossible, and I wasn't looking to drill big holes all over the my new outlander's rack!
so, using the pre-drilled factory holes with longer 10mm bolts made installing them a breeze- and they can be removed without having any damage to the rack.
TheATVSuperStore.com
Jan 19, 2012 03:34 PM
