E-TON RXL-90 NEW Adjustable CDI…..no spark??
Old Jun 27, 2022 | 03:37 PM
SNOTME's Avatar
Default E-TON RXL-90 NEW Adjustable CDI…..no spark??
I recently purchased a 2004 Eton Viper 90cc. This had installed the OEM CDI box with the green wire on the back. But since my daughter is newer to ATVing. I wanted to slow it down a little bit before being used to it. I installed an adjustable CDI box that came on model year 2005. But now I have no spark, all seems to be connected correctly, I switch back to the OEM box and sparks and runs good. This is the second box I’ve gotten since I thought the first was a defect. Is there a different wiring setup or factors, from the OEM CDI to the 1 year newer ADJUSTABLE CDI?
Old Jun 28, 2022 | 01:53 AM
Possibly, ETon kill switches generally use an earth to run CDI. My guess is one of those CDIs will be earth to kill, so won't work unless the kill switches are altered. Far easier to turn down how far the throttle lever moves on the handlebars. Before makers started getting too clever, this is how they cut max power, and I your thumb throttle will probably have the tapped hole for a throttle limit screw.
Old Jun 28, 2022 | 01:03 PM
SNOTME's Avatar
OEM CDI is on the right and the adjustable is on the left
all colors are the same, accept the OEM black/white stripe is blue/white stripe on the new CDI
Old Jun 29, 2022 | 01:57 AM
Have you wound the limiter to the max? If 0 does mean no spark at zero revs, you won't get a spark at 0.
Black with white stripe is almost universally kill switch on CDIs. Try leaving that blue/white disconnected on new CDI, try with it earthed if you don't then get a spark.
Old Jun 29, 2022 | 10:05 AM
SNOTME's Avatar
I have tried all the dial positions while turning over, no spark. Tried with kill switch in off position. Never tried with disconnected, I will try that.
Old Jun 29, 2022 | 10:11 AM
SNOTME's Avatar
These are the wiring diagrams
Old Jun 30, 2022 | 01:56 AM
Right, looks like that wiring set up is, as I suspected, earth to run for the kill switches. If your new CDI is earth to kill, leaving the kill wire disconnected would give a spark. Though trying with ign off would have the same effect, how did you turn starter with ign off? Only other possibility I can think of is a dud new CDI. Has your thumb throttle got a tapped hole for a throttle restrictor screw? Would save all this messing about if you fit one.
Old Jul 1, 2022 | 01:40 AM
SNOTME's Avatar
This is actually my second new CDI box, the first I returned after it had no spark. But after the second one had no spark I suspected another issue. I tried to start with the engine stop ( kill switch) off, ignition on. It has a throttle limit screw, but is already turned in all the way, where it barely moves. But since it is a CVT, still revs up enough to move the belt into a speeder position.
NickyA
May 23, 2021 05:20 PM
can-do
1) Engine problems..
Nov 24, 2009 10:17 PM
DEPALMA
Jun 24, 2007 08:41 PM
willfax
Dec 6, 2005 06:45 PM
akwood
Jan 7, 2004 08:47 PM
