Thumb Throttle
Old Nov 25, 1999 | 11:38 AM
DavidB's Avatar
Does anyone know of a thumb throttle extension or replacement for a 2000 Sportsman 500? I am missing my right thumb and currently operate the throttle with my palm. Any ideas or input will be greatly appreciated. Thanks in advance.
Old Nov 25, 1999 | 11:47 AM
quad_man's Avatar
You might try calling a company like HPD ( http://www.hpd-inc.com ) and look into a twsit throttle, it should be easier to use.
I don't that anyone has a extension for the '99 & '00 models because Polaris redsigned the thumb throttle.
Good luck!
Old Nov 25, 1999 | 12:15 PM
DavidB's Avatar
Thanks quad_man.
Old Nov 25, 1999 | 04:13 PM
BONER's Avatar
Drill 2 holes in the lever and screw a longer lever on it to were it reaches you palm better.
Old Nov 25, 1999 | 09:22 PM
A400L's Avatar
Try the "thumb saver". I've seen it advertised in the back of DW. Apparently its some type of extension that allows you to use your palm. The company is CDS Inc. (800)-791-1333. For $13.- (as of my 4/99 issue) it might be what your looking for.
Jerry Goodman '99 400L, '98 TBlazer
Old Nov 25, 1999 | 11:05 PM
quad_man's Avatar
Jerry---that's the one, but they don't make it for the new Polaris style.
Old Nov 26, 1999 | 01:05 AM
SCman's Avatar
I think I saw one in the Cabellas catalog. Try their website.
Old Nov 26, 1999 | 06:59 PM
Jack's Avatar
You can make one yourself from some straight aluminum stock and a couple of allen screws that you can countersink into the aluminum and attach nylock nuts. You only have to drill two holes thru the stock throttle, so you can go back to it if you want. The angle can be changed to suite your need. I made mine to help with using big mittens and use my palm many times when plowing snow.
I'll e-mail it to you . . .
<A HREF="http://www.godigital-design.com/96Polaris.html">Schultz Motorsports</A>
Old Nov 26, 1999 | 07:01 PM
corncob2's Avatar
I took a L shaped bracket and bent one leg straight almost looks like small s drilled hole in thumb thing put a bolt in it,Wala took care of POLARIS thumb.Easy to adjust just bend to fit.Best of all cheap. COB
Old Nov 27, 1999 | 09:00 PM
DavidB's Avatar
Thanks guys
I appreciate all of the ideas. I had tried Cabella's & others but no one made anything for newer than a 98 model. Jacks photo of the one he had made looks like the ticket. Again, thanks all.
Pehter
Oct 3, 2024 11:00 PM
hueby
Nov 6, 2015 11:34 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
