sp500 wont go into gear, neutral , reverse lights dont come on either
Old Apr 26, 2002 | 12:50 PM
mudmanatv4x4's Avatar
my sp500 wont shift into gear , wont shift into other gears, but it does drive forward(not sure if it is high or low) the lights on the pod dont work either(nuetral or reverse)??? what could cause this what could this be???
thanks
Old Apr 26, 2002 | 12:59 PM
xcrider's Avatar
Check your shifter linkage. DO you ever get it into nutral?
Old Apr 26, 2002 | 01:04 PM
its not the linkage, i took the tranny out to replace a broken chain put everything back in and now it wont shift
thanks
Old Apr 27, 2002 | 01:25 PM
help!!!!
Old Apr 28, 2002 | 03:27 AM
Old Apr 28, 2002 | 07:39 AM
mtpockets's Avatar
Mudman,
i have a '01 sp500 also. i was wondering what kinda chain there is in the tranny that needed to be replaced?
confused,
-MT
Old Apr 28, 2002 | 12:58 PM
SHAGGY500HO's Avatar
mtpockets
There are two chains in the rear case on the sportsman's.....I believe greg sims broke his awile back also. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 28, 2002 | 01:47 PM
Farmr123's Avatar
Sounds like you have a shift fork that didn't get lined up quite right inside the tranny.
Old Apr 28, 2002 | 06:11 PM
ok sorry for that delay, i broke the forward chain, which is the big chain. there is also a reverse chain(smaller). but yea i have the tranny out now and cant seem to get the forks into the case right?? i will put the case on and then i wont be able to shift it(using a pair of pliers). please help me out if you can
thanks
skinnyr6
Aug 25, 2023 02:18 AM
JoAnnS
Jul 23, 2015 02:18 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
