650 belt yelp
Old Feb 4, 2003 | 01:00 AM
grizzkiller's Avatar
Default 650 belt yelp
my brother has a 650 praire, has 1200 miles on it, the belt started to yelp or whine like a dog, he changed the belt once but it continues to do it anyone with info on this talking machine?
Old Feb 4, 2003 | 06:54 AM
nyroc's Avatar
It is loose. Tighten it down. Don't drive it like that because it wears the pulley faces fast. See my website for tech tips.
Old Feb 4, 2003 | 08:22 AM
trx450's Avatar
If it has JUST started "YELPING", you can most likely get away with using a shim stack that is .5MM less than what is in there now. If it has made noise for more than 200 miles or so, you'll need to go thru the tensioning process. Be sure to use a good strain gauge, or fish scale to accurately check your belt's deflection. I didn't think that I needed a "fish scale", and got mine WAY tight, the first time I adjusted mine. It will become routine, once you've done it.
GOOD LUCK!!!!!!
NYROC--- Did you get the Outlaw jpegs ??????? BTW- How long has" Nyroc's Knowledge Base" been in existence?
Old Feb 4, 2003 | 09:29 AM
nyroc's Avatar
I only posted one of the radial outlaw pics, I didn't think everybody wanted the closeups. Sometimes I like to see the 650 with different tires, so I have been showing 650's with various different ones.
Nyroc's knowledge base? It has been evolving for 6 months or so. I have been making minor improvements on a gradual basis. It is cake to use. My PC's at work and at home stay logged in (via a cookie), each tech tip has an edit button for me to make changes and correct misspellings right from the web browser. There are also buttons for upload file, rename, delete, and create new.
I have been thinking about killing the sections for yamaha, honda, and suzuki. I have also thought about trying to get kawasaki to spponsor me. I just haven't had time to spruce it up enough to try to ask kawasaki to take a look at it.
If you have any suggestions, please let me know.
Old Feb 4, 2003 | 07:57 PM
prairievenom's Avatar
Nyroc when i go to your website i dont see any belt tighting procedures,all i see is belt removal,deflection measurment,and defliction adjustment.
Old Feb 4, 2003 | 09:21 PM
nyroc's Avatar
"deflection adjustment" is another way of saying "adjusting belt"
You see how loose belts are by pushing on them halfway between the pulleys. The distance that the belt sags is called deflection. The tighter, the less deflection.
It would be incredibly difficult (mechanically, scientifically and financially) to actually measure the belt tension. So, they made it easier for us to check and adjust it just by the deflection.
Old Feb 4, 2003 | 11:37 PM
he changed the belt once and the old belt seemed reallly tight and the new seems just as tight!
Old Feb 5, 2003 | 12:54 AM
FastEd's Avatar
Grizzkiller,
A belt that "seams" properly adjusted may in fact be way out of spec. You have to measure the deflection like shown on Nyrock's webpage or in your manual. Unless you are some sort of magician/mechanic, you should use the proper tools to actually measure the deflection. I know that I can not tell the difference between 22 and 25mm of deflection by pushing down on the belt with my thumb. If the belt deflection is too great, you need to remove some of the shim thickness in the driven clutch. A slight squeal at idle in gear is ok. A slight squeal at takeoff means the belt deflection is too great and you are prematurely wearing parts. Good luck in getting to know the Prairie a little better!
Regards,
ED
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
