BIGGER Battery? Or run 2 Together?
Old May 27, 2009 | 08:25 PM
  #21
TLC's Avatar
TLC
The are aftermarket batteries you can buy with higher 18 AH and with 300CCA. Much better than your stock battery's 12AH and 175 CCA rating.
Just google "ATV Batteries and you will find them, West Co makes them but many others do as well.
Old May 30, 2009 | 04:01 AM
  #22
chuck_raduenz's Avatar
cupz71. nice and clean battery install. id like to do this to my polaris for the next winter as i have the same issue. battery drains when the headlights, hand/thumb warmers are on along with the winch and my led blinking lights. id also like to put mine under the rear rack above the tranny. or i may just find a bigger battery that will fit.
Old May 30, 2009 | 08:47 PM
  #23
HawkeyeRider's Avatar
Is anyone running the dual batteries using an isolator?? From what I have read, an isolator will keep you from over working the charging system.
Old Jun 1, 2009 | 05:00 PM
  #24
cupsz71's Avatar
Cool
THANKS! It work(s) really well.
HawkeyeRider - IF you wire the 2 batteries in PARALLEL your charging system should ONLY see it as ONE battery. You must pair up the batteries as close to the same AH rating so one doesn't "bleed-off" pwr to the weaker one The CCA isn't really a factor.
My AC battery is rated 12AH / 175CCA and the Walmart special lawn tractor battery ($20) is 12AH & 330CCA. It's CAPACITY/AMPS per hour you want. Your stator will happily put out about 14.4 volts when charging. It isn't perfect, but it works.
I also put a 1.5amp battery maintainer on when I know the TRV will sit for a while. It keeps BOTH batteries at 13.3 volts.
ITS: BAT#1 is normal hookup
BAT#2 is POS to POS on BAT#1 & NEG to the bike frame.
The maintainer is POS to BAT#1 and NEG on BAT#2
Old Jun 1, 2009 | 07:08 PM
  #25
nkkiegem123's Avatar
I'm not into with this topic but this was an informative article! my uncle has one and i can share this thread to him...thanks
bzdok1234
30
Feb 23, 2016 01:55 PM
Hunter100us
Oct 7, 2015 11:46 PM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
