dose any one know about carbs
on my 86 250 big red if i never tought the jets in the carb but i sat for a will then i cleand the carb and i did not do any thing to the jets then put it back on an it ran ok than it did not run ok it still ran but it sounded like it was geting too much gas and i try to adjust the air fuel mixture screw and still ran the same do u think that the jetts could be the problem or some thing else
any one know how to fix this and fast i just got 5 inches of snow and want to tear it up
thanks for the help[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]:
i doin the comprstion test in a few hours and do you think low compisstion whould make it sound like it is geting to much gas but it has alot of power but u just have to start off slow then you can give it some an it works it is just when it idles and then you go to take off is when this happens and i just fix the top end and it runs alot better than it did
thanks for the help
petcock filter is clean
thanks for the help
it almost sounds like maybe its not gettin enough gas......take your carb and gastank off, drain the tank and see if its rusty inside.....then take a peice of copper wire uand snake it through your main jet....break free all the gunk around the orifice that surrounds the main jet also. i got the same snow you did, but unfortunaly my 3 wheelers in peices (puttin the wiseco piston, gettin the head ported, just for kicks)
