tm45 vs Lectron 46HV
The new TM45 is $375. The complete set up TM45,port matched intake,cable and filter is $650.
The TM45 and the HV46 Lectron dynoed on a stock bike line for line up to the very top. Being a HV 1mm bigger drag carb, it should make more power. It wasn't huge, a 1hp and some ten's.
Yea Bom, I wasn't including the ported intake set up..... however if you include the ported intake on the Lectron, you're up to about $800. With the right tools and a little skill you can port your own intake......
almost forgot.. you can find the TM's in the "what's in your garage" thread. Make sure you are going back to the later threads thow.... I was on page 11 the other day and forgot to look at the date.
I'm seeing more Lectrons on there as well. Almost starting to see more lectrons than TM's......
DS650runner
01-04-2003 08:46 AM
