Skid Plates Outy 800?
i bought the ricochet for my renegade and my buddy did for his outlander.
you definitly need something! stoved in a-arm guard and destoyed boot.
i just cut them back a little.only other problem i have with them is the allen head bolts.
when they get dinged up you cant get allen tool in them to take the guard off.
check with your dealer friend. i got all the stuff on this just from my dealer. the skid plate is 2 piece 3/16 aluminum full-body the a-arm protector is made high strength aluminum.....plus has a drain plug..looks cool and has outlander embossed into the plate ...well worth the 125.00 us dollars
There has been a couple of guys who fabbed a compromise for the skid plate to accomodate the plow pusher plate. Most of us just take off the skids in winter.
Regarding the allen head bolts getting boogered up, I just went and got some std metric bolts to replace the allen head bolts. Don't forget to put 'never seize' on the bolts.
The guy I know with an Outlander fabbed his own out a a high density plastic material. Its pretty thick stuff and has a "greasy" feel to it which makes it slide really well over rocks and logs and stuff. The rocks don't seem to catch and dig into it like aluminum does.
If i remember right he did his with machine tools but you could probably do most of the fab work with common woodworking tools like saws and drills and routers which is a plus. Might be worth a look at your local materials shop for some plastic board stock if you're looking for a project.
10-10-2015 10:20 AM
