DS650 Spark Plug Odd Firing?
Old Jul 5, 2009 | 03:41 PM
yellowdemon23's Avatar
Default DS650 Spark Plug Odd Firing?
I was changing out the plugs on my ds the other day and noticed that the inside plug is firing correctly. The outside plug was dripping wet. I don't know anything about this question, in fact I don't know why it was even built with two plugs. Any info would be appreciated. I just noticed it didn't seem to be running quite right. Thanks guys.
--Steven
(p.s. I'm still looking for a rear shock as well)
Old Jul 5, 2009 | 06:41 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Put a good (gapped) plug in the boot not firing and then ground it to the motor and see if you get spark. If not change the plug wire and try. Its a start.
Old Jul 6, 2009 | 08:23 AM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
It has 2 plugs for improved combustion - another test is to check the resistance of the coils, both primary & secondary.
Old Jul 6, 2009 | 08:24 AM
Thanks guys, I'll see what happens.
Old Jul 6, 2009 | 08:30 AM
Forcefed's Avatar
Another quick test is to swap plug wires - if the spark issue goes to the other plug you have narrowed it down to - plug cap, wire, or coil.
The wires just twist in - it is advisable to unscrew them once a year or so & snip off the green corroded portion (usually 1/4 is all that it needs) and then reattach making sure the center of the wire screws onto the brass peg inside the plug cap securely.
Old Jul 6, 2009 | 08:49 AM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
All good info. I was on the dyno the other day making changes and a coil stopped working during a cam swap. Lost 5hp on a 100hp race motor. It gave no warning and took a while to figure out where the power went.
Old Jul 6, 2009 | 10:33 AM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
Talking
What kind of idiot would not have things like the coils up to date???? Amateurs I tell ya!!!
Old Jul 7, 2009 | 09:05 AM
Thanks, I'll swap the wires first and take it for a ride. I've got to find a rear shock soon.
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
