Temp guage sensor?
Old 01-23-2003, 01:51 PM
MudStud's Avatar
Default Temp guage sensor?
How much did it cost you?? I was thinking of just going to checkers here and getting the Autometers guauges for Oil and Temp but did not know the sizes. I know the oils is a 1/4 I heard? does that mean I can get any 1/4 gauge and it will work? I looked at the temp gauges but they seem so long? I 2 would like them on the dash...
Old 01-23-2003, 02:52 PM
JEFFROE's Avatar
the threads on the thermostat housing for the temp sensor is 1/8" pipe. each guage will have different sized thread depending on the unit. if you'r not running a tach ( seems more important to watch rpm's than oil pressure) than you should be able to mount one or two guages in that area. i have seen handle bar mounted digital guages for both oil pressure and water temp, leaving you room for you'r tach.
Old 01-23-2003, 02:56 PM
MudStud's Avatar
Yea, I do have the tach..So do you have to extend the tap to fit the new gauge?
Old 01-23-2003, 03:13 PM
JEFFROE's Avatar
yes the temp sensor pick-up at the thermostat housing was to long on mine two. so i just made an extension with 1/8 pipe to keep it from blocking off to much water flow.
Jeff Roper
02-01-2022 11:48 AM
vandammages@gmail.com
08-20-2020 11:50 AM
MikeyBoyesq
09-22-2015 10:02 AM
Jeff Roper
09-21-2015 02:11 PM
Quick Reply: Temp guage sensor?
