something is messed up in my clutch and i need help
Old 04-27-2003, 01:28 AM
brad650's Avatar
Default something is messed up in my clutch and i need help
i do NOT doubt anything hightower says, i know he is a DS geru. [img]i/expressions/face-icon-small-smile.gif[/img] but what should i do? short and simple? just keep trying or what?
  #22
Old 04-27-2003, 10:37 AM
Batoutahell's Avatar
Did you pull it back apart, something is in a bind if the arm will not move. You need to pull it apart and recheck it.
Bat
  #23
Old 04-27-2003, 01:31 PM
brad650's Avatar
the case is off, and im gonna try today, wish me luck lol
brad
  #24
Old 04-27-2003, 02:10 PM
JSsDS's Avatar
The guy at Alba is definately on crack!!! If you leave them loose, they will back out and make a mess of your clutch and case
The springs may be incorrect and when you tighten them down, all the coils contact eachother (coil bind) and will not collapsed anymore.
Measure the hight of the spring in the fully collapsed condition and compare with the stockers. You can put them in a vice to do this.
Then measure the shoulder portion of the clutch- spring bolt. the shoulder should be at least 1/4" longer then the collapsed length of the spring. I've had wrong parts in packages before
buddieboy
12-09-2016 05:50 PM
tysonbully
09-28-2015 02:30 AM
jbrewster94
09-23-2015 04:16 PM
roy.hawkins3@gmail.com
09-11-2015 02:35 PM
cdstang
08-31-2015 07:52 AM
Quick Reply: something is messed up in my clutch and i need help
