Speed Rating of ATV Tires
Old 02-21-2012, 05:58 PM
DrQuad's Avatar
Default Speed Rating of ATV Tires
Does anybody know what the speed rating of ATV tires are?
With the newer machines capable of higher speeds, I am concerned the tires may not hold up.
I currently run Mudbugs, but want a set of trail tires that can handle high speeds > 50 MPH.
Old 02-21-2012, 08:43 PM
HMT Racing's Avatar
Hum. Never really thought about that. I have had 26" swamp lites to 65mph on many occasions with 2psi of air. Dang now I have to go look them up.
Old 02-22-2012, 07:50 AM
I don't know that I'd be too concerned with speed ratings unless you're on pavement at high speeds. Just a thought.
Old 02-22-2012, 09:02 AM
DrQuad's Avatar
Maybe the better question is has anyone ever had a tire failure due to high speeds?
And if so what type/brand?
Old 02-22-2012, 09:20 AM
Not on my quad. Only failures have been a slashed sidewall from a sharp rock. I was able to stuff a few tire plugs in it and it held air for a couple years with no noticeable adverse effects.
Old 02-22-2012, 03:22 PM
user493's Avatar
Moto Psycho
I've never seen any speed rating on atv tires but I have seen where it says not for highway use.
Old 02-23-2012, 09:29 AM
TLC's Avatar
TLC
TLC is offline
None are meant to go Fast, the point of there 5 psi tire pressure in for slow rough off road condition. You Cant have fast great handling tires with only 5 psi pressure in them.
Sure many ATVs can go over 60 but none handle well doing it. The manufacturers know this thats why a 800cc ATV makes only 70hp while there 800 Sleds and PWC make 140hp.
They do not want to go to court like the old 3 wheelers did.
I guess you could put some high pressure street tires on a ATV but is would be pretty rough if it was driven off road where they belong.
Reactant
03-30-2022 02:08 AM
Ramman1
06-16-2016 09:07 PM
HYS
08-18-2015 12:28 PM
Scottma518
07-16-2015 09:19 PM
ranvette
07-12-2015 06:34 AM
Quick Reply: Speed Rating of ATV Tires
