recon going trough mud
Old Mar 25, 2006 | 12:11 PM
  #41
recon99's Avatar
Default recon going trough mud
What are you putting the lift kit on for? I don't think you're really going to benefit much from it, usually guys do lift kits when they put huge tires on it that won't clear the fenders. I'd leave it at the stock height, but wheel spacers would still be cool.
I don't like the idea of IRS on a sport quad, you end up with twice as may parts that wear out, and if you want to widen it you're looking at big money because you have to replace 8 a-arms instead of 4.
Old Mar 25, 2006 | 12:36 PM
  #42
hillclimbingrecon's Avatar
the reason i would put the lift kit on is so i could clear trees and rocks better because where i live i ride in the forest which is right next to a huge creek and i always get highsided on a log or rock. And plus i heard somewhere that if you put a lift kit on it will help you go through mud . And Also should i het a 3 inch wheel spacer or a 5 inch i ride in mostly tight trails? How fast has your warror topped out at because my freind has a blaster with 38 horse power and says it toped out at 80
Old Mar 25, 2006 | 12:58 PM
  #43
recon99's Avatar
I'd go with the 3 inch spacers. The last time I did a speed run I hit 68, but that was a year ago when all I had was the exhaust, and a bigger front sprocket. I'm thinking I might be able to get up to about 75 with my current mods.
Old Mar 25, 2006 | 03:00 PM
  #44
you might be able to beat a 450r in a drag race. I tried what you said on how do pop a wheelie and it works thakns alot. How much did you pay for you sur-tracks?
Old Mar 25, 2006 | 03:05 PM
  #45
recon99's Avatar
I don't remember what I paid for them, it was like 4 years ago, but maybe about $55 each.
Old Mar 25, 2006 | 03:14 PM
  #46
how do you put a snorkel on a recon and did you put a k and n air filter on your recon because i heard that it will give you more horse power?
Old Mar 25, 2006 | 03:21 PM
  #47
recon99's Avatar
Yeah, I had a k&n. I'm not real sure about the snorkel, i haven't kept up with the utility market since I got my warrior, so I don't know if you can buy kits for it or not. You might have to make a custom one out of pvc pipe if you can't get a kit. It involves cutting a hole in your front fender either way, so once you make the commitment you're stuck with it.
Old Mar 25, 2006 | 04:09 PM
  #48
yeah i have seen that on those big 4x4 quads. Did your K and N filter make the quad have more power or go faster? We
Old Mar 25, 2006 | 05:06 PM
  #49
recon99's Avatar
I probably gained a little power from it, but not enough that you can actually feel when riding.
Old Mar 25, 2006 | 06:02 PM
  #50
Thanks. hey you want to see a cool video go to sport quads and look up "you wont belive your eyes"It this guy who smokes a king quad on a 250ex
