250RX
Old 01-05-2001, 01:42 PM
EVEŽ§OLE's Avatar
Is it possible to place a 250r motor in a 250x frame without major complications?
Old 01-05-2001, 01:51 PM
cstark's Avatar
Anything is possible. But I think the pipe and radiator would require some creative thinking.
Old 01-06-2001, 03:31 PM
trick250rX's Avatar
Why work your way back? there will have to be some motor mount rearranging and probibly a custom pipe and might have to use a atc radiator, I wouldnt do it $$$$$do like I did and put a 250X motor a a R frame= major tourque and traction. How are you getting ahold of this R motor? why waste it there arent that many left
Old 01-06-2001, 03:59 PM
QuadDude05's Avatar
what about a 350x motor in a 250r frame? will that work?
Old 01-06-2001, 04:52 PM
Stroker's Avatar
Bud Fischer from Fischer Cycles built a 250R in an X frame a few years ago for the TT's. This would be the only thing worth building it for. The late Darren Naccaratoo (sorry about spelling) ran a LT500 in an X chassis at the TT's quite a few years back as well.
Old 01-07-2001, 02:48 AM
trick250rX's Avatar
The 350X motor works as well as teh 250X motor in the R frame but you have to motify the top right frame rail for the oil line to clear but its no biggy
Old 01-07-2001, 11:48 AM
EVEŽ§OLE's Avatar
How about a 350X motor in a 250X frame?
Old 01-07-2001, 03:13 PM
trick250rX's Avatar
Same thing but you will still have to make a custom pipe and mount the oil cooler
trick250rX
07-11-2000 01:50 AM
b(250rman)
06-21-2000 05:04 AM
Matt Ruszkiewicz
10
08-31-1999 10:02 AM
Quick Reply: 250RX
