Speedometer and shifting problems with a 01' 350 Honda Rancher
Old Feb 6, 2009 | 02:08 PM
shawnv's Avatar
Default Speedometer and shifting problems with a 01' 350 Honda Rancher
Well I bought a 01' Honda Rancher about a month ago and recently I have had issues with the electronic shifting. Everything will work fine for a while but after riding it for a bit the speedometer will read zero and I will not be able to shift out of the gear that I am in. All of the information that I found said that it was the angle sensor, so I went a head and but a good new one in. But alas the problem persists. Does anyone have any ideas on what could be causing this?
Old Feb 6, 2009 | 02:30 PM
HondaMechanic's Avatar
The speed sensor is 1 of the inputs for the ESP .. I would first check the speed sensor coupler for water/moisture , if it is clean the sensor is probably faulty ..
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
