P360 belt on P650?
Old May 28, 2003 | 11:37 AM
HONDAVAMP!'s Avatar
Default P360 belt on P650?
I have heard rumors that there are performance advantages to running a P360 belt on a P650.
Can someone tell me definitely if this is the case or not.
If it is tue, why and how does it help?
Are there any safety issues or reliabilty concerns?
What about additional wear on the sheaves?
I am in favor of anything that will help coax every ounce of muscle from this machine, as long as it does not sacrifice reliabilty. Any direction on this belt issue will be greatly appreciated.
Old May 28, 2003 | 03:12 PM
KISSSOFDEATH's Avatar
I have heard this too and would also like to know.
Old May 28, 2003 | 04:37 PM
HONDAVAMP!'s Avatar
I have also heard rumors of the 700 belt being a little thicker and wider.
Would this be another option?
Anyone tried to run a P360 or 700 belt yet?
Old May 28, 2003 | 10:48 PM
badprairie's Avatar
I think the 360 and 700 belt are the same.
Old May 29, 2003 | 01:13 AM
alltoys's Avatar
I run a 360 belt on my 650 as they slightly wider than the 650 and stronger. The 700 is approximately the same as the 360 belt but has the angle cut on both sides of the belt all the way to the top where as the 360 and 650 belt do not. The 700 belt is almost twice as expensive as the 360 belt. The 360 belt and 700 belt are the same width but wider than the 650 so you will have to reshim the driven sheave accordingly. It should give you slightly more on the top end.
Old May 29, 2003 | 10:21 AM
I found a place where the V700 belt is the same price as the P360. They were both $114.60. The P650 belt was $70.67. I might try the V700 belt when I need to replace mine. Even though the price was the same they have different part numbers, so something is different about them.
Old May 30, 2003 | 11:31 PM
AJ650's Avatar
Just a thought, but if the belt is wider, won't the extra width make it impossible for the belt to slide all the way to the inner area of the pulley and basically raise your 1st gear ratio?
Old May 30, 2003 | 11:38 PM
alltoys's Avatar
AJ650,
On the front or the rear sheave are you talking about or both and NO it will fit alright.
Old Jun 2, 2003 | 01:44 PM
roadrashron's Avatar
Alltoys, If I was to put a P360 belt on my P650 do I have to reshim the clutch. I have no shims in my clutch right now and my top speed is dropping bad, I can only getabout 59 out of the machine that used to run 67 every time. I have about 1500 miles on the belt, is it just time for a new one?
Old Jun 24, 2003 | 05:31 PM
Can someone say for sure that the P360 and KFX700 belts will work and how long are they going to last? Is it worth the extra money for the other belts?
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
