V-Force Tie Rod
Old Nov 24, 2003 | 04:13 PM
TechTip101's Avatar
Default V-Force Tie Rod
Who has the best and cheapest replacements for Tie Rods? I bent mine. I think the ends are still ok though...
Any suggestions would help.
Old Nov 24, 2003 | 05:01 PM
kawi700stud's Avatar
i bent my left tie-rod too. i called my dealer and and they told me the part wold be 40 bucks plus 2hrs of labor at 75 bucks an hour. instead i found a tie rod at fay meyers for 18 bucks and changed it out myselft in 15 minutes. very easy fix-up there are only two knuckles to unbolt and then re-thread the new tie-rod. just make sure that you mark on the new rod how far to turn in to the knuckle so that you keep the same toe-in angles. good luck
Old Nov 24, 2003 | 05:04 PM
TechTip101's Avatar
Thanks. I think I am going to install it myself. IT seems easy enough. Thanks
Old Nov 24, 2003 | 08:18 PM
Cheezhead's Avatar
List is only 9 bucks or so on that tierod if u didnt damage the ends its easy to replace.
Kevin
Old Nov 24, 2003 | 08:49 PM
2lman's Avatar
The heavy duty replacements from JD Performance were only $65 and are much heavier than the stock ones, well worth it in my book. Someone here just slipped a piece of pipe over the stock one and welded it up for a less expensive (and probably just as durable) fix, they have pics somewhere.
I bent my stock ones so bad they had a wiggle to them, and one of them bent just from riding, no collisions or wipeouts. The other one, well....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 24, 2003 | 10:15 PM
Doctor1's Avatar
Part Number: 39111-1180
Description: ROD-TIE
Price: $6.47
this is per www.ronayers.com
I went to buykawasaki.com looked up the tie it's under frame section for some reason but if they want to charge you 40$ your getting screwed you could buy 6 of them from ron ayer's and have money left over.
Old Nov 25, 2003 | 10:50 AM
TechTip101's Avatar
Sweet. You guys are awesome! I am all about cheap. I am under the impression that they are made so weak so that you don't break something more expensive. I'd rather by a dozen of them then have to replace the suspension or something. THanks for the help.
Keep the rubber side down
*...do as I say not as I do and you will
live longer and happier...*
Old Nov 25, 2003 | 01:03 PM
TechTip101's Avatar
JUst placed the order. Thanks everyone!
doggster
Nov 22, 2001 11:32 AM
azelmo
Sep 11, 2001 09:18 PM
azelmo
Jul 13, 2001 03:50 PM
adamnieman
Apr 22, 2001 07:31 PM
ctbanshee
Dec 2, 2000 11:10 PM
