Where to mount winch toggle on 03 Prairie 650?
Old Dec 1, 2003 | 03:12 PM
bryanp's Avatar
Default Where to mount winch toggle on 03 Prairie 650?
Just installed my Warn 25ci Winch on my '03 Prairie 650. There seems to be no room on the handlebar to mount the winch thumb toggle. Where has everyone been mounting their toggle switch on their prairies? Any one have any suggestions for places? Thanks!
Old Dec 1, 2003 | 03:45 PM
DirtyWhiteBoy's Avatar
Someone epoxied on the left side; so it stuck out from under the handlebar plastic.
I drilled a hole through the lower handlbar plastic with the toggle sticking out towards me. If I put a winch on my P700 then I will probably epoxy it like the first example. Both are fine, but, I think I like that better.
Old Dec 1, 2003 | 04:43 PM
therock's Avatar
Look at the bottom pic of my PAGE.
I swapped the side the angle bracket was on, removed the bottom lever clamp screw and got a longer one. I put a spacer behind the angle bracket to move the switch out until the fit was right. About 1/4' or so thick.
I am now looking for a water proof toggle switch that has the RED flip up cover to mount next to my gauge cluster so to prevent accidental winch movement.
Old Dec 1, 2003 | 07:27 PM
p700wheelieman's Avatar
on your left side brake perch there is 2 philps screws holding it on i took the bottom screw out and i found a bolt about 2'' long with same threads first i slide the toggle on then with a nut i fastened it to the end of the bolt now take another nut and thread it about 3/4'' on to the 2'' bolt now i screwed the bolt into perch and then tightened the nut up against the perch and secured nut against toggle works out sweet switch is right at your thumb and looks very clean i also put controler underneth body work right next to the air box on left side not under seat next to exuast pipe like they recomend and get good crimp on conecters #6 gauge for winch and battery cables to cut them to exact length
Old Dec 2, 2003 | 11:18 PM
Prairie700's Avatar
I just trimmed the plastic (actually I removed it - used a band saw - then sanded) on the L. hand side and mounted to the handlebar like the instructions show.
Old Jan 2, 2004 | 06:16 PM
BUDXXX's Avatar
THE ROCK- where did you get those rubber pads on the camo unit's racks. How much?
Old Jan 2, 2004 | 09:39 PM
650Pilot's Avatar
I just installed the same winch yesterday, and I put toggle switch on the handlebar right up against the differiential lock.
It fit great , looks great!
Old Jan 2, 2004 | 10:19 PM
Uncle's Avatar
I added the toggle switch to my Warn 2500. See pictures of install on handlebars. I can either use the remote switch or the toggle switch. The toggle is really handy for quick jobs.
Old Jan 2, 2004 | 10:24 PM
650Pilot's Avatar
What did you do with the 5' of extra cable under the seat?
Old Jan 2, 2004 | 10:29 PM
Uncle's Avatar
What cable I had left, I zipped tied to the frame under the seat. My relay is mounted to the back fender support.
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
