belt help
Old Oct 6, 2004 | 08:13 AM
crazy22's Avatar
Default belt help
i have a 03 650 p has i have replace the belt 4 times in less then 1000 miles . the dealer said the the front drive pully is worn and that why i am going threw belts . would that be a warr item . my dealer is a p__k and idears
Old Oct 6, 2004 | 10:42 AM
newbeatle's Avatar
Default belt help
most of the time, worn sheeves are considered a wear item... but dealers have quite a bit of leaway & if you dealer is difficult to work with, you'll likely end up buying new sheeves...
Old Oct 6, 2004 | 05:07 PM
Hayashi's Avatar
Default belt help
4 belts in less than 1000 miles and worn out sheaves?!
Man, that's too many! What do you do with your bike? Pulling a log in mud with the gear in High range? Make sure your belt deflection is at minimal with your new belt.
Old Oct 7, 2004 | 04:52 AM
crazy22's Avatar
Default belt help
most of the time in sugar sand at a good speed then playing in the mud in low . dont understand why
Old Oct 7, 2004 | 03:00 PM
Cuda440's Avatar
Default belt help
I also had a friend that was going through belts with his 02 P650. We did find the Primary (Front) clutch worn and the movable sheeve would wobble. We replaced it with a new Kawasaki factory one. Cost was about $420.00
Old Oct 7, 2004 | 04:38 PM
crazy22's Avatar
Default belt help
i have this problems for a long time i am going to take to other dealer
Old Oct 7, 2004 | 05:00 PM
Hayashi's Avatar
Default belt help
When I went to the Rocky Mtn ATV jamboree in UT last month, I met up with a whole bunch of P650/700 owners and a lot of them still had the same factory installed belt with 1000~2000 miles. And they were still running good. We went on a 100 mile long group ride and we even exchanged the ride. However, there was a couple of young guys who had to replace the belt before 1000 and they admitted they abused it. I guess it all depends how you use it.
Old Oct 7, 2004 | 05:24 PM
SpliffStar's Avatar
Default belt help
I just replaced my stock belt with a p700, I got 4000 miles out of my stockie and now it is my backup. My friend also has his stock belt in and its at about 3000 miles.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
