650 belt
Old Oct 29, 2002 | 06:46 PM
cueball89's Avatar
Default 650 belt
is it possable to strech a belt that only has 132 miles on it to a deflection of 1.25 of an inch? [img]i/expressions/face-icon-small-mad.gif[/img]
Old Oct 29, 2002 | 08:48 PM
nyroc's Avatar
Default 650 belt
Probably not. Kawi puts them on loose so you will have to get a new one sooner.
Take the shims out, put a black spring on, and you will get a lot more miles out of this belt (tighter is better, but make sure that you aren't too tight).
Old Oct 29, 2002 | 10:03 PM
cueball89's Avatar
Default 650 belt
according to the service manual i would need a lot of shims to take out to get it where it needs to be. i've not seen how many shims i have but what if all the shims are out and it's still to much. does the black spring change belt deflection? thanks
Old Oct 29, 2002 | 10:48 PM
nyroc's Avatar
Default 650 belt
black spring does not change deflection. It reduces belt wear and slippage.
Removing .1mm(.004) of shim tightens the belt 1.3mm (.051")
If you have a .6mm (or .8mm) shim remove it (put black spring in at same time) and check the deflection. 6 times .051 =~ .3.
So, 1.25-0.3 is 0.95". That is just the manual's rule of thumb stuff.
It almost appears that kawi left us in the cold without much more adjustment left in our pulleys. But, we can use the 360 belt which is wider in case the adjustment can't be made with a 650 belt. Hopefully gates will make us belts that are just a sliver wider than the kawi 650 belt.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
